× This is the optional category header for the Suggestion Box.
Leaking Fuel Tank
01 Nov 2024 16:59 #1 by Ronald Raty
Leaking Fuel Tank was created by Ronald Raty
  I would suggest removing all the trim around the tanks so you have full access to the tanks and fuel lines, drain the tanks and lines, then pressurize the wing tank system with low pressure air (mouth pressure is enough), then brush all the joints and seams with soapy water and watch for bubbles. This photo is of me testing my fuel tank for leaks. The rubber glove (I didn't have a balloon) acts as a pressure regulator so I don't over pressurize.
Time to create page: 0.078 seconds
