cruise rpm
  • Don Burquest
19 May 2018 12:50 #1 by Don Burquest
Replied by Don Burquest on topic cruise rpm
Thank you, Henry! Good advice at all times. I understand better now.
  • Henry Pasquet
01 May 2018 09:47 - 01 May 2018 09:52 #2 by Henry Pasquet
Replied by Henry Pasquet on topic cruise rpm
I notice that even in this weather my RPM often drops during the mag check due to carb ice. . I need carb heat to complete the mag check and restore initial RPM.. I always give a 10-15 second shot of carb heat immediately before taking the active. If RPM decays in flight, the first response is to pull carb heat. That will usually cure it. If not, check fuel, oil pressure, cylinder head temp, ect.
Last edit: 01 May 2018 09:52 by Henry Pasquet.
  • Don Burquest
01 May 2018 09:34 #3 by Don Burquest
Thank you, Alan! I get puzzled about these things sometimes, thank you for your good reminder. Don
  • Don Burquest
01 May 2018 09:33 #4 by Don Burquest
Thank you, Henry! Good reminder. Doon
  • Arlan Allen
30 Apr 2018 18:42 #5 by Arlan Allen
Replied by Arlan Allen on topic cruise rpm
The minimum RPM is a static RPM. 2050 rpm is minimum Full Throttle static run-up rpm.
Arlan
N3989H
SN4690
KDVT
  • Henry Pasquet
26 Apr 2018 14:08 #6 by Henry Pasquet
Normally not. Under extreme conditions, carb heat may be needed at any power setting.
