- Engine preheater
Engine preheater
- Louis Kempfer
30 Nov 2022 17:44 #1
by Louis Kempfer
Replied by Louis Kempfer on topic Engine preheater
Scott, I leave the cowling loose on the oil check side. Route a room heater with a piece of 6 inch flexible heat duct attached to it into the bottom of the engine. I have 2 blankets that I cover the cowling and all the air openings. I plug it into a timer that was about $20 at Amazon. Set it for 4 hours before flight. It starts and oil temperature is in normal range very shortly.
- Scott Monroe
12 Jan 2022 04:43 #2
by Scott Monroe
Engine preheater was created by Scott Monroe
Good morning everyone. Does anyone have any experience with the use of preheater on a 415-C they can share? Thank you. Scott
