- Rubber in Carburetor (415-C)
- Away
04 Aug 2020 22:36 #1
Replied by Ronald Raty on topic Rubber in Carburetor (415-C)
When I replaced my fuel lines, I just bought Parker Super-flex fuel hose from Aircraft Spruce. Cut to length, and clamp.
The following user(s) said Thank You: George Polos
- Randy Hirsch AP
04 Aug 2020 08:12 #2
by Randy Hirsch AP
Replied by Randy Hirsch AP on topic Rubber in Carburetor (415-C)
Hey George - you might try Vernon Gregory (803) 360-2061. He bought the Skyport inventory and might be able to supply you with the SMK-51 Fuel/Oil Hose kit.
- George Polos
03 Aug 2020 20:47 #3
by George Polos
Replied by George Polos on topic Rubber in Carburetor (415-C)
Hose and clamps
- Away
03 Aug 2020 20:13 #4
What type of connections do you have? A hose nipple and hose clamps, or a flared screw on connection?
- George Polos
03 Aug 2020 11:33 #5
by George Polos
Rubber in Carburetor (415-C) was created by George Polos
I recently found out that my Stromberg carb had tiny rubber pieces in it that caused it to leak. I assume that the rubber is coming from the fuel line but I saw no evidence of rubber in the gascolator when the mechanic serviced it for me six weeks ago. The carburetor has been cleaned and I need to replace the fuel line.
Does anyone know the part number for the fuel line for a C-75-12? Can it be replaced with an off-the-shelf fuel line? Anyone have a recommendation?
Thanks,
George Polos
N3665H
Thanks,
George Polos
N3665H
