- Raymond Knox
26 Aug 2026 04:49 #1
by Raymond Knox
Replied by Raymond Knox on topic Ercoupe 415-C 9CF Baggage Compartement STC and 1320lb Gross Weight STC
Its not “stainnless steel cowl cover”. It’s the panel over the header tank. Between the windshield and the firewall.
03 Jul 2026 14:07 - 03 Jul 2026 14:08 #2
Replied by Larry Snyder on topic Ercoupe 415-C 9CF Baggage Compartement STC and 1320lb Gross Weight STC
Converting to a D has NOTHING to do with the firewall!! It’s the skin that covers the cowl tank. It must be stainless. It also has nothing to do with the gas tank. You must:
Put a stainless steel skin over the gas tank
Make sure the orifices in the MLG are correct
Limit elevator up trsvel to 9 degrees
Have the ¾” trim tab
I believe these are required for the 1320 STC with the possible exception of the stainless steel skin.
Surely somebody must remember what to do. As far as I know an approved 337 is all it takes. Many C models were converted to D models to get that extra 140 pounds! A lot of people bought Ercoupes that were registered as 415C models and later got the FAA CD and were shocked to find the 337 that converted it to a 415D! At the time that meant a sport pilot couldn’t fly it (no longer the case).
Last edit: 03 Jul 2026 14:08 by Larry Snyder.
- David Gilson
03 Jul 2026 13:39 #3
by David Gilson
Replied by David Gilson on topic Ercoupe 415-C 9CF Baggage Compartement STC and 1320lb Gross Weight STC
I'm half way through the 1400 pound increase. I have the 337 approved but so far i can't figure out how to change the designation with faa. I contacted a dar that I've used previously and he said he needed to research it. If you know how that step is completed, I would live to know
- Away
11 Jun 2026 09:32 #4
Replied by Ronald Raty on topic Ercoupe 415-C 9CF Baggage Compartement STC and 1320lb Gross Weight STC
As I understand it, There is a certification requirement that the firewall not be aluminum. During certification, there were numerous modifications, one being the larger cowling that extended over the gas tank with only an aluminum sheet separating the passenger compartment from the engine. Nobody thought about how that compromised the "firewall" separation. The inclusion of the steel sheet in the STC is to correct that oversight.
- B Hage
11 Jun 2026 06:44 - 11 Jun 2026 06:48 #5
by B Hage
Replied by B Hage on topic Ercoupe 415-C 9CF Baggage Compartement STC and 1320lb Gross Weight STC
i am curious to understand how changing the stainnless steel cowl cover affect the capacity of the ercoup to carry more weight
Last edit: 11 Jun 2026 06:48 by B Hage.
27 Apr 2026 19:39 #6
Sorry I'm so late responding! Why buy the 1320 STC when you can just upgrade your coupe to a D model and have a gross weight of 1400? MOSAIC lets you fly it! You get 80 more pounds and the only difference in requirements between the STC and the D model conversion is the stainless steel cowl cover!
