- Motor mounts.
Motor mounts.
- Frank Hamelly
14 Sep 2025 15:49 #1
by Frank Hamelly
Replied by Frank Hamelly on topic Motor mounts.
Yes. The mounts were overdue for replacement due to sagging. I am an A/P and am aware of the offset that must be maintained as per design. It is done and flew with no issues. Thanks for your input.
14 Sep 2025 00:47 #2
Replied by Brooks McNew on topic Motor mounts.
Very good idea to point that out in case anyone tried to make the engine point straight forward! I was assuming that he had more "sag" than the normal, correct thrust line offsets.
Besides, I don't think the Continental mounts would shim like the Lycoming ones I saw on the RV8.
13 Sep 2025 23:06 #3
Replied by Matt Gunsch on topic Motor mounts.
you cannot "shim" the engine mount, it is designed with a nose down and to the side mounting. when on the ground, the lower Fwd side and upper aft side mounts are under compression.
18 Aug 2025 20:42 - 23 Aug 2025 16:10 #4
Mike, I have NO idea about the Forney mounts specifically, but I did just help someone hang an engine on an RV8. Mainly I was the nearest guy who owned an engine hoist but I did get to help out with the whole process.
Specifically, they hung the engine and then checked the alignment where the crankshaft came out of the front cowling - to see whether the spinner would be centered. It would have been too low in the hole (the sagging you refer to?) and slightly to one side.
They had additional washers, just like the pair of washers that came with the new engine mounts - to shim the motor mounts and center the crankshaft in the front of the cowling. It ended up needing two extra washer/shims on the lower left mount, one on the lower right mount, one on the upper left mount, and no additional washer/shims on the upper right mount. This swung the crankshaft into the proper position.
Again, I have no idea whether this applies to your situation, but since I just saw this happen firsthand I figured it was worth mentioning.
EDIT: I looked at a diagram of the Forney mount. It's really hard to tell whether or not this would work because the drawing didn't show the engine and engine mount. They're definitely different then those used in the RV mount. If you want to post a photo of an assembled engine mount -or- let me know what you end up doing to center the engine I would LOVE to know how this works out.
Last edit: 23 Aug 2025 16:10 by Brooks McNew. Reason: spelling
- Frank Hamelly
17 Aug 2025 15:02 #5
by Frank Hamelly
Motor mounts. was created by Frank Hamelly
Replacing motor mounts on 1960 Forney. Have the new ones in. Prior to torque and safety, is there a way to “center” them so the bottom ones don’t appear to sag? These are Lord mounts made in US. Mike.
