- Control Yoke Mounting
- Away
21 Feb 2022 11:49 #13
Replied by Ronald Raty on topic Control Yoke Mounting
- Shawn DUFFEE
20 Feb 2022 20:29 #14
by Shawn DUFFEE
Replied by Shawn DUFFEE on topic Control Yoke Mounting
Thanks Warren. I am trying to see how to mount the yoke mast to the fuselage. I see the bottom has two holes for bolting on to the bottom of the fuselage, I see the elevator rod, but that's as far as I can figure. I can see why the pushrod needs to go on first.
Then there's some rigging to do. I will need to figure that out.
I just need some visuals to jumpstart the process.
Thank you
Thank you
20 Feb 2022 18:59 #15
Replied by Warren Hampton on topic Control Yoke Mounting
Shawn go to craigslist for Reno Nv there is an ad for a Coupe Over priced but there is a picture of a green mast. But I am confused is it a mast or control Column you are talking about. I have taken pics of the mast in my 415
20 Feb 2022 14:55 #16
Send your email to me I can get a picture. This email address is being protected from spambots. You need JavaScript enabled to view it.
20 Feb 2022 14:44 - 20 Feb 2022 14:49 #17
One of the hardest things to do on and of the Coupe family is to get to the mast Four 1/4- 28 bolts hole it to the airframe but the cotter pins are a bitch to get to. Then the control rods need to be done first. The Coupe needed a removeable bottom like Mooney M20 have. Maybe you could do a 337 to make an Insp cover to work under the mast ( ? ) that been done under the control column. Ps see my views on the suggestion column... And then comment.
Last edit: 20 Feb 2022 14:49 by Warren Hampton.
- Shawn DUFFEE
19 Feb 2022 12:46 #18
by Shawn DUFFEE
Control Yoke Mounting was created by Shawn DUFFEE
Hello All!
Does anyone happen to have any detailed photos of how the 415 control mast mounts to the airframe? I am not finding any visuals or specs on bolts, etc. Any photos, diagrams or narratives would be appreciated, as would a suggestion as to where to look. Thank you!
Shawn
Shawn
