- Replacement fuel pressure switch for M4007-4, o-200 crankshaft electric pump
22 Jan 2020 15:37 #7
Replied by Lawson Laslo on topic Replacement fuel pressure switch for M4007-4, o-200 crankshaft electric pump
Forgot to mention the model number is M4007-4
- Dale Huffman
22 Jan 2020 14:21 #8
by Dale Huffman
Replied by Dale Huffman on topic Replacement fuel pressure switch for M4007-4, o-200 crankshaft electric pump
Lawson, Thanks for the info. Will give them a call.
Anyone else with info. or alternative source of M4007 / replacement part # would be appreciated.
21 Jan 2020 10:33 #9
We replaced the defective fuel pressure switch in the ercoupe recently
We purchased it from Vernon Gregory
(803) 360-2061
www.usedercoupeparts.com/Contact.htm
(803) 360-2061
- Dale Huffman
20 Jan 2020 14:30 #10
by Dale Huffman
Replacement fuel pressure switch for M4007-4, o-200 crankshaft electric pump was created by Dale Huffman
Hello, we recently purchased a 1946 ERCOUPE 415C that has the STC o-200 crankshaft conversion. Therefore it has an electric fuel pump and M7004-4, 4psi normally closed pressure switch that fills the header tank. It appears that the M7004-4 switch is not available. Does anyone know of a source or of the the replacement listed in the current STC. Thank you
