- Hum on landing
Hum on landing
- 9912
16 Oct 2015 09:21 #1
by 9912
Replied by 9912 on topic Hum on landing
Problem appears to be solved. Turns out to be (I think) loose inspection port cover.
Ted
Ted
- Cathy Boyko
28 Sep 2015 19:47 #2
by Cathy Boyko
Replied by Cathy Boyko on topic Hum on landing
Oh, I must clarify, the stuffed toy is an aviation-grade stuffed toy, LOL. I have added it to the "required equipment" list and "weight and balance" for the aircraft.
- 9912
28 Sep 2015 16:18 #3
by 9912
Thanks, Ill try it out. I had vibrating windows before but stiffeners at the base cured the problem. Maybe it came back. Today I checked the cover plates on the bottom of the wing before I did a few touch and goes and found one out of kilter. No hum on these landings, so maybe that was it.
Ted
Ted
- Chris Schuldt
28 Sep 2015 16:14 #4
by Chris Schuldt
Replied by Chris Schuldt on topic Hum on landing
Mine vibrates as well sometimes on either side. I can sometimes move them a little bit and it'll quit otherwise I have a small piece of fabric that lays in the gap and cuts down on the vibration. I think it's caused by a certain frequency of harmonics. My have all of the correct stiffeners and It still happens
Chris
Chris
- Cathy Boyko
28 Sep 2015 16:02 #5
by Cathy Boyko
Try stuffing a small stuffed animal in the window gap to keep the window from moving. Mine started vibrating when I had new windows put in ( just my side). I'm thinking the new material was not as age hardened as the outgoing plexiglass. Also for some reason my left window has a smaller bottom aluminum channel than the other (non vibrating) side. Only vibrates at lower air speeds (take off and landing) which is super annoying. I need a thicker channel on the bottom of it, but for now the stuffed toy works. Could be in your case that certain window positions don't do it and you found one that did.
28 Sep 2015 10:50 #6
Replied by Larry Snyder on topic Hum on landing
That's a weird one. Sounds like you're on the right track. Let us know what you find.
Larry Snyder
Larry Snyder
Time to create page: 0.085 seconds
