- Please help with nose wheel vibrations
- Bob Thompson
27 Jun 2019 07:11 #1
by Bob Thompson
Replied by Bob Thompson on topic Please help with nose wheel vibrations
And now almost two months later it is back but occurs under different conditions!
Over the weekend it started doing it on landing rollout only on pavement. It is smooth on takeoff but almost as soon as the nose drops on landing it vibrates until speed is down around 25-30.
- Bob Thompson
20 May 2019 13:28 #2
by Bob Thompson
I should have also mentioned that we changed all the nutcracker hardware as well.
- Steve McNew
20 May 2019 12:26 #3
by Steve McNew
Replied by Steve McNew on topic Please help with nose wheel vibrations
My bird wears retreads, and is happy with them. STeve
- Steve McNew
20 May 2019 12:24 #4
by Steve McNew
I had the same problem a couple of years ago - my cure, suggested by my favorite A&P, was to replace the bolt that secured the angle of the nutcracker, the V shaped contraption, on the aft side of the nosewheel mount. The old bolt, perhaps original, was visibly worn; the replacement with a new bolt cured the situation. Beats me why, but it is hard to argue with its success! Good luck!
- Bob Thompson
19 May 2019 17:10 #5
by Bob Thompson
Thx folks...it seems to have gone away after changing the tire and tube.
- Tad Daughters
15 May 2019 15:11 #6
by Tad Daughters
Replied by Tad Daughters on topic Please help with nose wheel vibrations
In my personal case, tightening the nut cracker helped, as did keeping the nose tire pressure around 18-20 pounds, but it wasn't totally cured until the nose gear assembly was rebuilt. There were worn bearings in it. My A&P/IA is also a Director with many years experience on the 'Coupe, so if the easy things don't work, find an experienced A&P who can help you.
Time to create page: 0.076 seconds
