Brake master cylinder
  • peter stephany
08 Oct 2018 20:39 #1 by peter stephany
Replied by peter stephany on topic Brake master cylinder
Thank you, excellent, now on to nose gear strut, any suggestions for overhaul material?
07 Oct 2018 13:39 #2 by Ronald Raty
Replied by Ronald Raty on topic Brake master cylinder
Also, if you are rebuilding the master, check this out.
www.ercoupe.info/?n=Main.MasterCylinderOverhaul
07 Oct 2018 13:24 #3 by Ronald Raty
I looked back through my records, I apparently used these:
master cylinder
AN6227-23 (MS28775-218) O-ring
AN6227-07 (MS28775-012) O-ring
AN6227-16 (MS28775-211) O-ring
MS28775-13 shim
  • peter stephany
07 Oct 2018 10:18 #4 by peter stephany
Brake master cylinder was created by peter stephany
Anyone know correct P/N for O rings in original Ercoupe master cylinder?
