- Is there a club CFI database ?
11 Apr 2024 01:32 #1
Replied by Larry Snyder on topic Is there a club CFI database ?
Bruce, never apologize for saying I was right!
- Bruce Bennett
10 Apr 2024 23:57 #2
by Bruce Bennett
Replied by Bruce Bennett on topic Is there a club CFI database ?
I find Larry and I had this STC discussion two years ago. Larry is correct
about calling Alpha and the 9 degree requirement. I forget things. Sorry.
I apologize for the off-topic.
10 Apr 2024 19:28 #3
It is required to reduce the elevator travel but it’s buried somewhere. I think I may have called Alpha.
- Bruce Bennett
10 Apr 2024 18:33 #4
by Bruce Bennett
Not to create confusion but the Alpha Aviation web site on the 1320 STC
requires 415C and CD models to have the larger 1 and 3/8" trim tab
instead of original 3/4" trim tab. It does not mention a change from
13 degrees to 9 degrees. Does the actual STC specify the degree change?
- James Davis
10 Apr 2024 13:17 - 10 Apr 2024 13:19 #5
by James Davis
Replied by James Davis on topic Is there a club CFI database ?
I meant the 80 lb increase of 1320 to 1400 doesn't require any power increase or structural component change.
That 80 lb increase just happens by the magic of the paperwork?
That's what I wanted to point out!
Last edit: 10 Apr 2024 13:19 by James Davis.
- Michael Hainen
10 Apr 2024 12:55 #6
by Michael Hainen
Replied by Michael Hainen on topic Is there a club CFI database ?
Ouch!
Time to create page: 0.132 seconds
