Anti-collision Light Suggestions?
24 Aug 2021 14:16 #7 by Tim Cowden
Replied by Tim Cowden on topic Anti-collision Light Suggestions?
Matt,
That looks like an excellent recommendation, I will get it for my Coupe.
Thanks again,
Tim
24 Aug 2021 13:44 #8 by Matt Gunsch
Replied by Matt Gunsch on topic Anti-collision Light Suggestions?
Thank you for the compliment, Most Coupes, mine included have a strobe on the belly, This is what I have on my coupe
www.wagaero.com/the-flight-strobe-12v-faa-pma-d.html
24 Aug 2021 10:43 #9 by Tim Cowden
Matt,
You are a veritable fountain of knowledge!  I see you on this forum all the time helping your fellow Coupers and I really appreciate the effort.  Thanks for clipping that FAA language for me.  This is why I think I'd like to get a rotating beacon or strobe, assuming it does not cost me too much weight.  The language about coverage areas is really complicated but I think the gist of it is that if I mount a rotating beacon on the fuselage somewhere behind the cockpit either on top of or below the fuselage I should be able to meet that requirement.  Is that how you read it?
Thanks again,
Tim
23 Aug 2021 20:04 - 23 Aug 2021 20:18 #10 by Matt Gunsch
see FAR 91.205(c)(3), I believe all you would need is a rotating beacon.
Here is the part 23 from 1971 rgl.faa.gov/Regulatory_and_Guidance_Libr...071CBFC?OpenDocument
Last edit: 23 Aug 2021 20:18 by Matt Gunsch.
23 Aug 2021 12:12 #11 by Tim Cowden
Matt,
Thanks for weighing in.  You make good points.  It is my impression that an anti-collision light is needed to legally fly after sunset.  While I don't plan to fly my coupe at night much, I can visualize times in the winter where I might be returning after dusk when the sun is setting around 4:30pm.  Do you think I am required to have it for night flight?
Tim
21 Aug 2021 13:39 #12 by Matt Gunsch
is there a reason you want them ? it is added weight and electrical load. They are not required equipment. if you want to pursue it, Whelen would be your best choice, but you might have to change your nav light assemblies as well.
