- Fuel pump VARMA approval
- David Hetrick
11 May 2025 08:23 #1
by David Hetrick
Replied by David Hetrick on topic Fuel pump VARMA approval
Thank you, I am going to show this to my mechanic. I noticed the price of this kit went up $20 since I looked at it last.
- David Gilson
09 May 2025 09:15 #2
by David Gilson
Replied by David Gilson on topic Fuel pump VARMA approval
Nothing was wrong with mine. I just saw a path to help all the coupers save some money and now everyone can get there own approval much easier. The kit from then and now contains all of the required items for the yearly AD plus everything to completely rebuild the pump if you choose at half the price of just the bolt and screen from aircraft spruce
- David Hetrick
09 May 2025 09:07 #3
by David Hetrick
Thank you, I had another coupe owner tell me he had to do the same thing. He removed the arm and trued up the pump mounting surface.
- Super User
09 May 2025 08:58 #4
by Super User
Replied by Super User on topic Fuel pump VARMA approval
I battled the same issue on my previous engine and it turned out the fuel pump to casing flange was not flat. I had a local shop "true it up", got it signed off, and put it back on with no further leaking.
- David Hetrick
09 May 2025 08:51 #5
by David Hetrick
Just curious what was going on with your fuel pump? I have an oil leak from or around the my mechanical fuel pump which I thought was the mounting gasket which we replaced but I still have the leak. I am thinking it maybe leaking at the roll pin holes or the diaphram may have a hole in it. Appreciate any insight. Thanks
20 Apr 2025 00:27 #6
Replied by Matt Gunsch on topic Fuel pump VARMA approval
just click the download symbol on the embedded PDF in his post
