- Tie down eye bolts Alon A-2
- Away
22 Jun 2025 22:07 #1
Replied by John Jones on topic Tie down eye bolts Alon A-2
Indeed. Mooney apparently changed all the part numbers to their own system. Alon used a lot of the original 415-xxxx and F-xxxx part numbers but have some proprietary Axxxx numbers. In many cases the Forney "F" part numbers seem to have just dropped the 415 prefix. A lot of the parts will interchange between models it seems, and the prices can vary as well, sometimes Mooney is higher, sometimes less.
- Richard Kuehner
22 Jun 2025 20:57 #2
by Richard Kuehner
Replied by Richard Kuehner on topic Tie down eye bolts Alon A-2
Thanks. Love the confusing labeling of the parts some times. Here is entertainment I punched that part number into Univair and it came up with two options. $12 for the Ercoupe eye bolt with that part number. $20 for a Mooney eye bolt of a different part number that in description says alternate Mooney part number is the $12 Ercoupe part number……….
www.univair.com/search.php?search_query=...4044§ion=product
- Away
22 Jun 2025 20:47 #3
My Alon parts manual lists part number 415-14044 as the proper one for all three positions. That shows up on the Univair site.
- Richard Kuehner
22 Jun 2025 15:41 #4
by Richard Kuehner
Tie down eye bolts Alon A-2 was created by Richard Kuehner
Can anyone confirm compatibility. Univair only lists the eyebolt for Mooney M-10. Are the wings between A-2 and A-10 identical? I don’t have any tie downs on my wings at all and sure would like to tie her down when I travel away from home hanger!!!
I won’t be home to see my reference manual for a bit and want to order some. Oshkosh is coming!!!!
https://www.univair.com/mooney-m-10/parts/210308-000-m-10-tie-down-eye-bolt/
