- M10 Service Manual Correction - Engine Mount Rubber Busing Torque
- Alon/M10 Specific
- Mike Then
30 Jul 2022 21:28 #1
by Mike Then
M10 Service Manual Correction - Engine Mount Rubber Busing Torque was created by Mike Then
I came across the subject error today, at least it is in a few older M10 service & maintenance manuals I have. I would assume it is still wrong in the most recent publishing.
Under 3-9 Engine Installation, section 1 states the torque is 180 to 190 inch pounds. I strongly suggest the correct torque is 70 to 80 inch pounds. If you reference the TCM Overhaul manual, it references C90-16F use lord mounts, and gives the 180-190 torque. Well, we do not have lord mounts! The TCM Overhaul manual references 70 to 80 inch pounds for the mount set up we have.
I wasted sometime today figuring this out -- thought I'd save someone the trouble and pass it on.
Mike
Mike
- Alon/M10 Specific
