- Engine cooling
Engine cooling
29 Dec 2025 21:24 #1
Replied by Brooks McNew on topic Engine cooling
I made a pair of winterizing plates for me 'Coupe, one with a smaller hole in the center and one with no hole. The one with no hole wins in cold weather. For more increased oil temperature, there are insulating bags that zip around the oil tank.
The strangest effect is that the "winterizing plate" with the small hole works great in the summer. My oil temperature doesn't rise, but my cylinder #1 & #2 CHT's come down significantly. This must be due to lowering the pressure in the bottom cowl therefore pulling more air down through the cooling fins. I never see oil above 190 (maybe 200 in a hot, hard climb) but previously my Cylinder #2 was the limitation for a hot hard climb.
- James Vlahos
22 Dec 2025 20:21 #2
by James Vlahos
Replied by James Vlahos on topic Engine cooling
Chris
I would like to have a copy of the if possible?
Thank you
Jim
Thank you
Jim
- Greg Webber
17 Dec 2025 23:56 #3
by Greg Webber
Replied by Greg Webber on topic Engine cooling
- Chris Carlisle
- Chris Carlisle
08 Jan 2018 16:59 #4
by Chris Carlisle
Replied by Chris Carlisle on topic Engine cooling
Well....... As it turns out, if you look closely at the pic, there are little holes on either side of the big oval center hole under the spinner. They are backed with nut plates. Looks like someone in this poor plane's long past put SOMETHING over that hole which has long since been lost.
So, I took Larry's very helpful Skyport engineering drawings and enlarged them on my printer enough so that the resultant size just overlapped those holes, traced it onto a 0.040/30 piece of scrap aluminum stock, and cut it out on the band saw. Screwed it in place with lock washers and now the oil temp comes off the peg in anything over about 20 deg OAT. The cabin heater works better too.
Thanks again Larry for your help. Anyone else need the template let me know and I'd be glad to mail a copy for the usual fee of $5000
Actually, it's free and I'll even pay for the stamp.
Chris
Chris
- Jack Arthur
18 Dec 2017 10:05 #5
by Jack Arthur
Replied by Jack Arthur on topic Engine cooling
I have used some foam like from a foan cushion, cut it a little large and stuff it in the hole behind the prop and it helps.
Jack
Jack
- Chris Carlisle
17 Dec 2017 19:49 #6
by Chris Carlisle
Thanks Larry. That'll be a big help, even if for no other reason I know what hole to plug up now.
Chris
Chris
