- Gascolator
Gascolator
27 Jan 2025 23:06 #1
Replied by Warren Hampton on topic topic change from Gascolator to spark plugs
I go back to Radios. The old Radio did NOT cancel the spark noise like newer Radios do. Better now. Even cars could get radio noise back in the '50s and '60s ! When plugs and the wires them self were shield you could not get the top cover on with them in. Especially that left front plug. Not saying being without cover is not a nicer look. Nor am I saying with newer radios you will get noise. FYI I do not care.
- Bruce Bennett
24 Jan 2025 10:10 #2
by Bruce Bennett
Replied by Bruce Bennett on topic topic change from Gascolator to spark plugs
FWIW Eisemann mags came on the 415C and did not use shielded plugs, hence no bumps or holes in the cowl. I like
the smooth clean look and cringe at putting eyebrows on it
There aren't many Ercoupes left with smooth cowls.
23 Jan 2025 16:35 - 23 Jan 2025 16:41 #3
this plane was using ERCO engine. see the shape of the nose. Note also no radios
Last edit: 23 Jan 2025 16:41 by Warren Hampton. Reason: Add more
23 Jan 2025 16:32 #4
Old type plug were replaced because of radio became used more.
- Bruce Bennett
11 Jan 2025 13:28 #5
by Bruce Bennett
To Ronald: Yep. A good looking plane.
To Kevin:
Apparently I wasn't clear. I am an American and bound by FAA rules.
I was hoping someone knew of an unshielded alternative to the M41E that could keep the FAA happy.
To Kevin:
- Away
10 Jan 2025 19:51 #6
Replied by Ronald Raty on topic topic change from Gascolator to spark plugs
